In Library>Genres, there are missing genres. I can see the genre “Lofi” on multiple of my albums, but that genre does not show up under Genres in my library.
Am I misunderstanding what Genre is supposed to mean in the Library tab?
You’re not misunderstanding the genre list. Your logs confirm that “Lofi” matches two albums, but has no entry in the synced genre list. The album tags and the genre list are imported separately from Plex.
The upload captures the browsing steps, but not the sync that built that list. Could you please enable debug logging, open Sync manager and long-press your Plex provider’s sync button to force a full sync? Wait for it to finish, check Library → Genres, then open an album and tap “Lofi” again.
Please disable debug logging and upload the logs promptly using this guide. Reply with your app version, upload description and reproduction time so I can check what Plex returned during the sync.
Thank you, I can confirm that the full sync completed correctly, and the new logs show the cause.
Plex returns the same genre as lofi in its genre list and Lofi on your albums. Symfonium treats those names as different when counting the genre’s contents, then removes the lofi entry as empty. That explains why it disappears from Library → Genres while tapping the album tag still finds your albums.
This is a genre-matching bug in Symfonium. I have the sync and browsing evidence I needed from this upload.
Oh sweet I helped find something! Good to know it’s not just me. In the meantime I’ll just throw together some smart playlists, the filters on those seem to handle the genre tags a little cleaner.
This support response time is crazy fast btw, thanks for the help.
