That’s a shame, I figured this would be a tough one.
I tried snooping around in logcat for any hints but I got nothing.
Perhaps the album art metadata is not getting added properly to the media session? Most other media apps work just fine. I’m not sure what moto display uses, if it’s either the URI or Bitmap version, or if it uses the “key art” version or not.
Of note, the open source Finamp player does display album art, perhaps it would be worth looking into how they’re doing it?
Failing that, I’d just hope and pray the upcoming Android 13 update fixes this
Without the device to repro it’s impossible to know. Could just be that the image I set is too high quality and it can’t handle it. Or nearly anything.
Since everything works everywhere else, I can’t just guess here. Their support could maybe help.
