Merging album for 2 disc in one place albums not separate
I hope that Symfonium can merging album if there are 2disc or even more in the album release
This makes it easier for us to play songs especially sequentially just like we play CD tapes
To be simple in appearance, there are not too many albums with the same name because they have been merged into one and are not separate
You have full control over how albums are merged … See the split album setting in the provider settings.
Where can I find the settings you described? Because in the tag there is a description of disc 1 and disc 2 on a file, while other apps can. For example Salt Player, Poweramp, UAPP, FIIO Music, Sony Music
I hope like this
for example: Salt Player
in reality of Symfonium
As said on the provider settings the split album setting control that.
ahh ok, just unlisted the folder section. finally found it
thank you
