Memory card compatible
IT’S NOT A PROBLEM IT’S JUST A QUESTION IS THE PLAYER COMPATIBLE WITH THE SD CARD
Upload description: IT’S NOT A PROBLEM IT’S JUST A QUESTION IS THE PLAYER COMPATIBLE WITH THE SD CARD
 Not provided
Well it did not took long :frowning: Use the chat function for such questions.
Yes it’s compatible select local device since your sdcard is on your local device.
