When resuming a session from yesterday, I got errors that my media was unavailable.
Trying to remove and read the server I get an authentication failure. I am able to log in through the web and the jellyfin app with the same connection URL and credentials.
Jellyfin server does not log that there was any log in attempt, invalid or otherwise.
I don’t have any proxy set up. Unsure what security setting could be blocking it, could you give me an idea of where to look? Default jellyfin app and web logins are working just fine locally and through external IP.
When on the local network, I have the same problem trying to connect using direct local IP. If that helps eliminate some of the potential problems.
There’s more in the log, if you don’t mind taking a look. Did a restart, log starts with the shutdown command and goes for about 300 lines. Tons of repeated auth errors, but 232 has the 400 error you pointed out.
