Lock screen Page
Basically when on the lock screen the album cover or a custom photo is shown with a few buttons, most players I’ve used before have this so surprised it wasn’t here.
Well not having to unlock one’s phone everytime to add songs to playlists or check queue
A lock screen layout that can be edited to one’s desired custom look
i have symfonium installed on a dedicated audio player. i often use the stock android “pin app” function when i’m not intending to do anything else with it, since the lock screen notification isn’t great. this means i can quickly check the queue, or let my friends check what song is playing on my stereo, or look up the lyrics. it works really well, but pinning and unpinning is pretty annoying. kore has a setting (“show over lockscreen”) that basically automatically pins it if you lock the screen with kore open, and i’d love a similar setting for symfonium.
Same. I just have the lock screen disabled. Screen turns on, and you’re in the app. If you dont want to disable the lock screen, you can pin the app and get the same kind of behavior
my friend, the post i made had more than one sentence in it. you should consider reading all of them before responding.
Let me know if you need a recommendation on where you can put those
Keep it civil if you don’t want a ban.
And for the record sentences starts with an uppercase letter :wink:
I concur this suggestion. Particularly the seek bar on the lock screen would be great, and having controls bigger than in the regular notification bubble (full screen) will make them much easier to press, especially when you’ve added extra buttons (I have play/pause, next/prev, +/-10sec, for a total of five).
Another good reference is BlackPlayer, which I used before switching to Symfonium. This has the feature ‘custom lock screen’ which is similar to the main now playing page.
