On the same album, the tracks do not play. While this same album plays without problem on other players.
Upload description: Maestral17
The FLAC files are corrupted you can easily check and fix them with flac command line tool.
You can also try to uncheck the option prefer internal decoder to see if your phone decoder allows playback of those invalid files.
