Read the github page. All the information is there.
For audiomuse-ai, I am curious how long a 5million song scan will take them. My 250kish library is going to take over two months in the end.
Depends on your CPU, there is also a NVIDIA docker test file which utilize supported NVIDIA GPUs and can dramatically speed up the analyzing (up to x12 I have read) I have not tested it though.
My library of approx 30K songs on a Ryzen 5 3600 took about 24 hours +/-
In the end its worth the wait in my opinion. The backend paired with symfonium has totally evolved my listening experience and rediscover my music library.
I’m using my synology to run it. Is this docker file on their github?
Yes its all on github. I don’t use synology myself but you will need a way to run a custom docker app.
I had a question how would I be able to get the lrc that are like Apple music with the translation as I know it’s been implemented but I wanted to know a easy way of doing it fast for my 6 million songs automatically
