Upload description: Bithoarder
Peeking at the uploade log, it looks like it’s database queries that are taking most of the time, one of the extremes are:
Error/QueryBuilder: Query: SELECT provider_id, SUM(DISTINCT offline_status + 1) - 1, COALESCE(genres,“”) FROM songs GROUP BY provider_id, genres (‘’) [82136 in 719.31ms (RAW/false)]
I wonder if my database is either corrupted, or it is lacking some indices, or if I have an unusual use-case that is not covered by the normal indices.
It is slow to delete cached offline files, it takes 2-3 seconds per file.
