Issue with duplicate tracks and missing network restriction settings in version 14.0.0
Hi Symfonium Support,
I am having an issue managing server connections in version 14.0.0 (127708). I am trying to set up a Navidrome (Subsonic) server using two different routes to avoid slowness and ensure connectivity:
Primary Connection: Tailscale IP (100.X.X.X) for remote access.
Secondary Connection: Local IP (192.X.X.X) for home use.
The problem is that every time the library refreshes, all my tracks get duplicated. I am trying to fix this by using the “Network Restrictions” feature to limit the secondary local IP to my home SSID, but I cannot find that option anywhere in this version’s menus.
I have already looked under Settings > Interface > Advanced, but the “Expert Mode” or “Network Configuration” buttons seem to be missing or moved.
Could you please guide me on how to enable Expert Mode correctly or tell me exactly where the “Configure network restrictions” button is located in this specific version? I want to make sure the app only uses one connection at a time to prevent duplicates.
Thank you in advance for your help!
Navidrome
1-Configure Navidrome server with a Tailscale IP as Primary Connection.
2-Add a Local IP (192.168.X.X) as Secondary Connection.
3-Refresh the library.
4-Observe that all tracks are duplicated.
5-Try to find “Network Restrictions” or “Expert Mode” to limit the Secondary Connection to home SSID, but the option is not visible in the menus.
Don’t use random LLM to try to do things :wink: You are looking for things that do no exist.
You either properly add a secondary connection inside the provider settings or use the global filter to switch between both providers.
Please, could you tell me how to solve my issue? I feel your previous answer wasn’t as clear as I expected, and the AI has been my only source of help so far.
I do not have duplicate files on my server. When I only use one connection, everything works perfectly. However, as soon as I add the secondary connection (Local IP) and refresh the library to add new songs, the app doesn’t just add the new ones—it duplicates all the previous tracks as if they were on a different server.
How can I correctly set up the secondary connection so Symfonium understands it is the same provider and stops duplicating the library?
Have you even tried to read what I wrote and search the docs for those parts ? I’m sorry but I can’t take everyone by hand and do search and screenshots to repeat all the stuff from the docs.
Edit your provider to add a secondary connection … Do not add another provider …
Use the global filter if you have multiple provider to switch.
Look, there’s no need for that tone. I am asking for help with a potential bug in the app, and the direction this conversation is taking isn’t good for either of us. If it bothers you so much that I used an AI to try and solve this, that is not my problem. I prefer to try and fix things myself first so I don’t have to bother support, and I only reach out when I can’t find a solution, which was the case here. I have read several documents, and none of them address my specific issue.
Anyway, I finally managed to solve it on my own, and it wasn’t thanks to the documentation or your support. I don’t like being confrontational, but when a user asks for help and gets this kind of response, it’s very disappointing.
I do NOT need any MORE replies. Thanks anyway for your time.
I gave you the solution twice and yes it’s in the doc.
On the other end, you do not bother to write your solution to be able to help other people searching for this ?
I’ll skip the fact that you actually did not upload the mandatory logs nor searched for duplicates.
So yes maybe the kind of response kinda match the kind of post you made :wink:
