Is it possible to loop a song a stated number of times?
Hi,
I’ve downloaded the app and it looks fantastic.
In terms of song looping, I have noticed that with the icon ‘1’ the song loops an infinite number of times and without that ‘1’ icon the song does not loop, whether the loop symbol is highlighted or not, it only loops when the ‘1’ symbol appears.
Is there a way to loop the track a stated number of times… Whether this be 5, 6, 7 etc? If this isn’t possible at the moment, is this a feature you’re looking to implement?
Thanks and once again I really appreciate the app, it looks amazing.
Josh
Upload description: No logs, just asking about implementation of a feature
No there’s repeat off, repeat current song (the 1) and repeat all the queue that’s all.
I mean if you know how long the song is and how many times you want it repeated, you could use the sleep timer as a workaround.
Want to play a 3 minute song 5 times? Set the sleep timer to 15min while having the repeat1 option turned on.
