Is it possible to combine 2 Smart Playlists
I have a smart playlist that selects 80 tracks that I have rated 8 or above. I have another smart playlist that selects 20 tracks that I have rated 6. Both of these use the Random Stable sort.
I then want to combine them into 1 playlist. I have tried to create another smart playlist and used the’in smart playlist’ for both my original playlists. However, when I open this playlist it continually says it is loading.
Plex
As above
Create 2 smart playlists and attempt to combine them into another single playlist (smart or simple)
Geoff555
Yeah the 2 times album is compilation causes issue. Remove from the sub playlists for now and apply to the merging one. Will work better in next release.
Thanks Tolriq, I will try again when the next version is issued.
