Today after doing a image cache purge images are no longer being downloaded from my Navidrome instance. Even with the “Automatic Image Cache” option being enabled
Not really. If it fails getting images from external providers it try the next option in the CoverArtPriority configuration. If it is the last option, it returns a placeholder. See Artwork resolution | Navidrome
@jaxz , as the linked issue suggests, try to delete Navidrome’s cache and restart the server.
Yes it tries the next but some apps have small timeouts so when it will fetch from external source it can timeout too. I’m like at 5 seconds for first byte for images to avoid endless stuck.
Anyway I guess the workaround will do for the moment, let’s hope people see those 2 threads before complaining.
