Images not cached randomly
Log ids:
darrenwjlau
darrenwjlau-2
Images would be cached then suddenly disappear
Upload description: darrenwjlau-2, darrenwjlau
Something delete the images from the cache.
See https://dontkillmyapp.com/ and disable optimizers you may have installed.
I have no optimizers and I already follow all steps when I first install
Your phone have some default ones …
Open the folder /storage/emulated/0/Android/data/app.symfonik.music.player/files/images see that the images are properly written there.
Then see that the images are removed from there and it’s not Symfonium doing it.
How can I disable them
and yes its there
I could use some adb commands if needed
Also would moving it to a sd card prevent this
I do not know what your device do, so can’t really tell more at this point.
Its a HyperOS 2.0.6.0
What step I can try more?
I found a turn off system optimization in dev settings, gonna try
Seems to work
Thanks @Tolriq, also can I request custom local for external sd cards
