How to update smart playlist?
I have created a smart plalist to find unrated titles (Ratin < 1). When I now rate a title in the player, it is also shown in the playlist with a rating greater than zero.
But what I am looking for is, that the title will be removed from the list, because it does not match the criteria anymore.
I have an identical smart playlist on my Navidrome server and there, the rated songs are removed from that list. I cannot find a way to refresh the list to reflect the changed rating.
Navidrome
Create smart list based on rating
change rating for a song so it does not match the smart list criteria anymore
argumon
I don’t read German, but please note that there are two (2) options for rating.
In English, these are labeled as “Rating” and “User Rating”.
When you change a rating in the app, that is saved to the second field–to the User Rating. Your playlist is probably looking at the other Rating field, which is why the song hasn’t been removed from your playlist.
To answer the other question, these is no way to “update” the Smart Playlist on-demand because they are already, always updated.
Thank Celorion, I changed my criteria to User Rating and it immediately works as expected. Oh, and BTW I found the setting to switch the UI to English. Well done, most Apps only support the device language. So next time I will attach screen shots in English.
