Symfonium is using a lot of battery even while closed.
I’ve not used it a lot this week, like twice and it’s used 40% out of all apps. This is with Symphonium closed. Tonight it was not open at all and it used 40% compared to all other apps.
The screenshots does not show any onscreen or background values that’s strange.
In the logs the app is killed at 9PM. The OS restart the app at 10:21PM for whatever reason. The app just init itself then do absolutely nothing after. The system audio track is not even started.
This looks like something connects to the app MediaBrowser and the OS report the system usage as the app usage.
