Yesterday I noticed that the app was using an abnormally large amount of mobile data. In just half an hour of listening (with a lot of skipping between songs), it used 3.8 GB.
For comparison, YMusic used around 300 MB over the course of 7 days.
I installed GlassWire and checked the data usage. When I played 20 random songs for about one second each (by repeatedly tapping skip), Symfonium used 100–200 MB of data. While I was testing different options, it downloaded over 1 GB in total.
It seems like the app immediately downloads the entire song as soon as playback starts.
My server is a home Jellyfin server.
I also tried Finamp, and in that app everything worked as expected.
- Install GlassWire
- Play any file
- Skip to next song
- Repeat at lest 10 times
- Check data usage with Glaswire
djole
