I’m using a Hiby R6 III (Android 12) which has some hardware buttons. All of them work fine, except for the previous button. Holding the previous button also doesn’t do anything.
I think the control mapping is under the Headset button menu in Playback options if I understand the documentation. The next and previous buttons are both configured accordingly. I’ve also verified that they work in the Hiby music app to rule out a hardware failure. I’ve also tried Button Mapper Pro to add a previous button to the hardware, but that didn’t work either. So maybe it’s not just a Symfonium issue.
Could you take a look at this? Anyway, love the work you’ve done and I’ve gladly purchased the app before the trial expired. Hopefully this will help you make it perform even better.
Upload description: Scalage
Play an album and use the hardware buttons on a Hiby device with Android 12 and you’ll notice the play/pause and next buttons work fine, but the previous doesn’t.
