I’ve been unable to get GROUPING tags to show for M4A files
I’ve tested GROUPING as well as CONTENTGROUP
Upload description: GROUPING_TEST
I’ve included my test file under the same description as my logs.
Not sure if this is a mistake on my end, limitation of MP4 container or a Symfonium thing.
Using MP3 tag I added a GROUPING tag to my MP4 (M4A) file & attempted to re-sync my library
Sync was successful but there remained no GROUPING tags visible.
I attempted this again using CONTENTGROUP, same result
Another attempt using both, same result.
I also tried clearing my tag cache & then running the sync but the results were the same unfortunately.
