Grouping and/or contentgroup tags: goes in "work" for MP3 and goes in "grouping" for FLAC & m4a
I use Mp3tag and TagScanner to set the tags of my music files (MP3/FLAC/M4A).
I fill both the Grouping and Content Group fields (TagScanner seems to use both fields with the same value) and use them as a broader “music genre” for my library.
Example:
Genre = Indie Rock
Grouping = Rock
I expected to use this field for smart playlists.
What I see in Symphonium:
When i see the file details in symphonium, most of my files have the “Work” field set with the value of the Grouping (or Content Group) field from my music files.
Some of my files have the “Grouping” field in Symphonium correctly set with this value.
After investigation (creation of smart playlist on the presence of grouping, then for work), I found that:
  • Case 1 (mapped to “Work”) occurs for MP3 files
  • Case 2 (correct “Grouping”) occurs for FLAC and M4A files
What I expected:
The Grouping field from my files should be mapped to the Grouping field in Symphonium consistently, regardless of file format.
SMB
1: in MP3/flac/m4u set tag grouping and contentgroup
2- synchronize the file in symphonium
3- in symphonium, open the details fo these files and check which field is set with the value entered in th eMP3/flac/m4u files.
At this point, I’m not sure whether the issue comes from Symphonium or from how Mp3tag/TagScanner write the tags. But at least Mp3tag and TagScanner are both consistent on this grouping/contentgroup fields
gues sno log needed for this situation, sorry if i was wrong
Someday I really do not understand what more I can do …
Without logs, the files and the actual tags what do you expect me to answer ?
But yes it’s probably a mix up on your taggers, some tags have official meaning and apple meaning.
