Beta
Hi,
When I apply a custom font using the font name from Google Fonts, the font is applied successfully. However, the font weight used for headings and other text appears lighter compared to fonts selected from the built-in dropdown menu.
I’ve attached examples using Lexend Deca (available in the dropdown menu) and Google Sans Flex (applied as a custom Google Font). Although both fonts support a 900 font weight, there is a noticeable difference in how bold they appear when applied.
- Apply font available in the drop-down menu and compare it with font applied using the Google fonts method.
font-debug-AA
