Freezing phenomenon
When using the app, it freezes and crashes when selecting a song.
Upload description: ncs3 Freezing phenomenon
In the manage Symfonium files there should be a .and file that I’ll need.
Even better would be https://developer.android.com/studio/debug/bug-report
The bug report is below:
Module metadata package name: com.google.android.modulemetadata
Duration of ‘DUMPSYS CRITICAL’: 1.38s
Duration of ‘EVENT LOG’: 0.14s
Duration of ‘STATS LOG’: 0.02s
Duration of ‘RADIO LOG’: 0.12s
logcat: Logcat read failure: No such file or directory
*** command ‘logcat -L -b all -v threadtime -v printable -v uid -d *:v’ failed: exit code 1
Start thread pool:1
Adding dir /cache/recovery (recursive: 1)
Adding dir /data/misc/recovery (recursive: 1)
Adding dir /data/misc/update_engine_log (recursive: 1)
Adding dir /data/misc/update_engine/prefs (recursive: 1)
Adding dir /data/misc/logd (recursive: 0)
/data/misc/logd: No such file or directory
Adding dir /data/misc/prereboot (recursive: 0)
MOUNT INFO: 115 entries added to zip file
Duration of ‘LPDUMP’: 1.07s
Duration of ‘DEVICE-MAPPER’: 1.05s
Adding dir /metadata/ota (recursive: 1)
execvp on command ‘iotop -n 1 -m 100’ failed (error: No such file or directory)
*** command ‘iotop -n 1 -m 100’ failed: exit code 1
Duration of ‘Dmabuf dump’: 0.81s
Duration of ‘DUMP TRACES’: 19.31s
Duration of 'Wait for ': 15.64s
shutdown thread pool
Start thread pool:3
Warning: Skipping “[email protected]::ICameraService/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IDisplayService/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::ISensorManager/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IAtraceDevice/default”: cannot be fetched from service manager (null)
section 1000 status 1
Warning: Skipping “[email protected]::IBootControl/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IMediaCasService/default”: cannot be fetched from service manager (null)
section 1000 status 2
section 1002 status 1
section 1002 status 2
section 1109 status 1
section 1109 status 2
section 1110 status 1
section 1110 status 2
section 1111 status 1
section 1111 status 2
section 1112 status 1
section 1112 status 2
section 1113 status 1
section 1113 status 2
section 1114 status 1
section 1114 status 2
section 1115 status 1
section 1115 status 2
section 1116 status 1
Warning: Skipping “[email protected]::IGatekeeper/default”: cannot be fetched from service manager (null)
No IDumpstateDevice AIDL implementation
No IDumpstateDevice HIDL implementation
Could not find IDumpstateDevice implementation
Failed to unlink file (/data/user_de/0/com.android.shell/files/bugreports/dumpstate_board.bin): No such file or directory
Failed to unlink file (/data/user_de/0/com.android.shell/files/bugreports/dumpstate_board.txt): No such file or directory
Warning: Skipping “[email protected]::IKeymasterDevice/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IOmx/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IOmxStore/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IRadioConfig/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IRadio/slot1”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IRadio/slot2”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::ISap/slot1”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::ISap/slot2”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::ISecureElement/SIM1”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::ISecureElement/SIM2”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::ISecureElement/eSE1”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IOffloadConfig/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IOffloadControl/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IUsbGadget/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IUsb/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::ISupplicant/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IAllocator/ashmem”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/AtCmdFwdService”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/DpmService”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/MwqemAdapter”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/SIM1”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/SIM2”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/Uim0”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/Uim1”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/UimLpa0”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/UimLpa1”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/ashmem”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/clearkey”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/com.qualcomm.qti.uceservice”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/default1”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/default2”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/deviceinfo”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/dpmQmiService”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/dspservice”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/eSE1”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/external/0”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/imsrtpservice”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/internal/0”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/logreader”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/oemhook0”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/oemhook1”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/qccsyshal”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/qtee-vm”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/qti-tee”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/qti.ims.connectionmanagerservice”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/slot1”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/slot2”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/software”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/somchook”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/somchook2”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/threesixtyra”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/uimRemoteClient0”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/uimRemoteClient1”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/uimRemoteServer0”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/uimRemoteServer1”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/vppService”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/widevine”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/wifidisplaysession”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/wifidisplaysessionaudiotrack”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/wifidisplaysessionimagetrack”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBase/wifidisplaysessionvideotrack”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::ITokenManager/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::INetd/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IKeystore/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IdpmQmi/dpmQmiService”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IImsCmService/qti.ims.connectionmanagerservice”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IUceService/com.qualcomm.qti.uceservice”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IDisplayColor/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IDisplayPostproc/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IDms/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBiometricsFingerprintRbs/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::INxpEse/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::INxpNfc/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IFactory/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IEsePowerManager/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IBTConfigStore/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IService/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::ICapabilityConfigStore/default”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IDataConnection/slot1”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IDataConnection/slot2”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IIWlan/slot1”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::IIWlan/slot2”: cannot be fetched from service manager (null)
Warning: Skipping “[email protected]::ILinkLatency/default”: cannot be fetched from service manager (null)
Warning: Skipping "[email protected]::IDpmService/DpmServ
This is not a bug report it should generate a zip file. Upload to https://upload.symfonium.app do not paste here.
But there is many errors in that extract, can it be corrupted SDcard or no more space left ?
This content has been uploaded. Please check.
Can you show your now playing screen config ? Did you do any special configuration there ?
Can you try to load one of the default and see if the issue is fixed ?
Edit: And backup the current one first so I can eventually reproduce.
Compact player
We will upload your backup data, so please check there for details.
Does reverting to another one fix the issue ? In all cases I need just the json of the now playing style.
Reverting to default does not improve it.
I uploaded the json file.
If reverting does not fix then I do not really have an idea :frowning: Have you tried the usual reboot of the phone ?
I have tried restarting the device, reinstalling the app, and clearing the cache, but nothing has helped. However, I have 45,000 songs stored in my Subsonic, and 6,560 songs added to my playlists. Could this be related to the issue?
I have 330 000 and some users millions so no it’s not a size issue. Maybe some compose bug specially on your device.
Does it only happen when starting from that screen?
I’ve tried it on other devices and the same thing happens.
Please answer the question, I also have a lot lot lot lot lot users and no other reports and no ANR reports on Play Console about that so let’s avoid generalization and help me find the issue specific to your case.
I’m sorry, but I’m Japanese, so I’m using Google Translate to help. So, there may be some misunderstanding between what you’re saying and what I’m conveying. I assume what you’re asking is, “Does the same symptom occur on other devices (smartphones)?”
I took a screen recording, so please take a look.
Assumptions:
- In the video, the game freezes when trying to play the next song immediately after the first song, but sometimes it freezes from the moment the first song is played.
- The subsonic (Navidrome) server and the device playing the game are on the same network, and they are connected via WiFi, not via a special connection like a VPN.
- The network connection speed is over 500Mbps for both download and upload.
- The play queue is empty except for the playlist being played.
- The device used is an Xperia 5 IV, a fairly recent generation smartphone that works without any problems.
- Other devices used include an Xperia 5 III and an OPPO Find X3, and the same issue occurs on all of them.
- All devices have been updated with the latest software.
No the question was in other screens.
Or only in that very large online first playlist ?
This also happens with other playlists (unspecified large number of playlists with tens to hundreds of songs), but not as frequently as with the first huge playlist.
