Beta
Playback fails completely when Symfonium is set to Original quality (raw FLAC streaming). Every track triggers a notification: “Error playing media. Make sure your player supports it”, then Symfonium skips to the next track. After exhausting the queue, a second notification appears: “Too many failed attempts. Stopping playback.”
This happens with any FLAC file.
Navidrome
- Open Symfonium and navigate to Settings → Player → Decoding & Transcoding → Max bitrate on Wi-Fi
- Set it to Original
- Go to any album or playlist and press play
- Observe: a push notification appears immediately saying “Error playing media. Make sure your player supports it”
- Symfonium skips to the next track and repeats the same error
- After cycling through several tracks, a second notification appears: “Too many failed attempts. Stopping playback”
What works
- Playback at 320kbps (OPUS transcoding via FFmpeg) works correctly
- Navidrome confirms FFmpeg is available:
Found ffmpeg path=./ffmpeg.exe
What does not work
- Any Original quality request fails on the client side
Navidrome server logs (no errors on server side)
When playback is attempted, Navidrome logs the following with no errors:
level=info msg="Streaming file" artist="Michael Jackson"
bitDepth=0 bitRate=0 cached=false channels=0
format=raw originalBitRate=1055 originalFormat=flac
sampleRate=0 title="Wanna Be Startin' Somethin'"
transcoding=false user=Misopita
The server streams the file successfully from its side. The failure occurs on the Symfonium/Android side.
Attempted workarounds
- Created a FLAC→FLAC transcoding profile in Navidrome and assigned it to the Symfonium player → Navidrome still returns
transcoding=falsewhen Symfonium requests Original, as the server respects the raw request by design - Switched to Jellyfin server using Symfonium’s native Jellyfin connection → same playback failure
Notable observation
Navidrome reports bitDepth=0, sampleRate=0, channels=0 for these FLAC files in the stream log, even after a full library rescan. The files play correctly in local players (AIMP on PC), confirming the files themselves are not corrupted.
Forum user: Misopita. Issue: FLAC raw streaming fails on Navidrome/Subsonic.
