Error syncing pushing playlists to provder
I wanted to push my playlists to my provider, emby, and I keep getting an error.
I uploaded the log files in the app
Emby
Goto to playlist
Select a playlist
Select the three dots on the right
Select the sync option
Select the option to push/replace on/to the provider
ERROR occurs
Error syncing playlist
2026-04-05 06:26:38.943 Error EmbyLogger  Request Error (0/0): 403 [User Marvin does not have access to ManageServer feature.]
You do not have the permission for that.
I changed the login provider ID and I still get the error when trying to upload a Playlist
The new log is called
after changing provider login ID
2026-04-05 11:14:41.358 Error EmbyLogger  Request Error (0/0): 403 [User Marvin does not have access to ManageServer feature.]
I’m sorry but you need to check your server logs and the logs yourself, I can’t do provider support.
