Would be great to be able to delete songs you added by mistake when your adding songs instead of going to playlists to manually erase it there sucha a easy minor feature but very helpful
Helps save time going to playlists to erase songs you added by mistake on the now playing menu instead
Helps to not do it manually each time u add songs to the wrong or duplicate on playlists
Have not seen on any such music player would first ive seen in
Being able to erase songs on this page by just clicking on playlists you added song by mistake to erase duplicate on this page from screenshot i took
