EQ Settings / Profiles Linked to Specific Genres
Would be awesome if in the future we could link specific EQ Settings / Profiles to a specific genre.
I am listening to classical music with a specific EQ settings & profile and then change genre to EDM, R&B or Rock. I manually have to change & select the EQ Settings / profile for the respective genre I am switching to
Easier switching of EQ Settings / profiles when genre changes.
Playlists with EQs and other options attributed to them would be cool too!
How would this idea cope with multiple genres per file?
Say, if you are playing a song that is tagged with Rock with the Rock EQ, then the song changes to one that is Pop with the Pop EQ, then it changes to a song that has been tagged with both Rock and Pop; which EQ would win?
fair point! from my side I don’t combine genres so I never thought that far. Perhaps one can select the various genres for a particular EQ / Profile.
In either case I suspect the implementation will not be easy :o
