Easily identify each BETA Changelog
Hi
this feature request is not directly related to the app at all, but, I feel this is still the best way to present it to you.
I have been a beta tester for quite some time, and, with each new beta you are really doing massive amounts of work and each changelog is rather big. From my experience there are usually 3 to 4 betas. Currently, there is no easy way to see what has been addressed in each following beta from the last one.
For example, if I download beta 2 today, I cannot easily see what you have worked on since beta 1 without comparing the changelogs directly with each other.
I know you add new stuff to the end of each changelog list, but, for the sake of clarity, I would really appreciate if newly added or changed items could be in a different coloured font for example, or in bold. Anything just so its easily to pick up the most recent from each new changelog.
Easier to follow each beta changelog without having to compare one with the other directly.
Makes it much easier to follow each new beta changelog. Would also help to easily identify if for example an issue you have, has already been addressed in latest beta release.
