DLNA streaming not working
I cannot stream to an Audio pro speaker via DLNA, streaming to other DLNA enabled devices has worked previously (also doesn’t work for other speakers that utilise linkplay Chipsets)
Upload description: boylie101
I’ve tried various options and combinations e.g. proxy via symphonium with and without alternative flags etc and different songs. It does sometimes work very briefly.
Seems to indicate connectivity issue with the server.
There’s no errors in the logs, the device accept the commands and don’t say anything after.
Can you cast from files located on the phone ?
Yes I can stream songs saved on the phone. It also now seems to be working now I’ve switched to using an IP address instead of a domain name for the server.
