DLNA doesn't play next track
DLNA only plays current track unless manually told to play the next track
The DLNA device I’m using is the Mi Smart Speaker Art, if that helps
Upload description: Allen-Chen-DLNA-(cast)-no-Auto-next-track
Device is Mi Smart Speaker Art
Connect to DLNA playback device
Play playlist
Optionally, drag the timeline to the last few seconds of music to ensure faster testing
The logs covers a couple of different things, but you press next before the track reach the end.
The track is 3:33 the renderer says it’s position is 1:56 so far from the end and still playing.
There’s never an end of track in those logs.
Huh, one sec
This one (DLNA-2-Allen-Chen) should have an instance
I can’t upload screen recordings though
Update: there’s something funky going on, when I press pause, it goes to the next track, smh
Is no enough I need proper details …
In the logs I see it’s working
2025-07-11 01:42:56.860 Verbose UPnPRenderer  Status changed to stopped (0)
2025-07-11 01:42:56.860 Verbose PlaybackController  autoNext
2025-07-11 01:42:56.862 Verbose PlaybackController  Play: 5 - true - All/true
So please properly describe the issue and what you do to trigger it.
I think it’s a client side issue, closing for now
