Different format display between screens
There is a difference in format displaying between the Now playing screen and Queue list. The queue does not have any issues with the format, as evidenced by the screenshots provided. However, the now playing screen is unable to display it and instead displays “Unknown”. I was interested in what could be causing this. Thank you.
Upload description: PewPew_unknown_format
This is due to your tags (Specially the TRAKTOR4) that is too large for the version of ffprobe I use :frowning:
The queue shows the data as extracted by taglib during scan, but the now playing shows more accurate data due to possible transcoding and many other cases.
For now the only solution is to remove the TRAKTOR4 tag if you don’t need it.
