Descending sorting for favorited tracks (on home page)
Beta
The the “Sort by” option in Settings > Home page (page settings) > Favorite tracks > Media doesn’t seem to support toggling ascending/descending and I couldn’t find another option for it either. I’m not sure if I’m missing something here and I didn’t see a post about it either and would appreciate your help.
In case it doesn’t exist, should I open a feature request?
It’d be nice to re-use library Sort by menu for example.
Version 15.0.1 (127798) - Using the custom/beta F-Droid repo
Navidrome
  1. Go to Settings > Home page (page settings) > Favorite tracks > Media > Sort by
    1.1. See it missing a toggle for descending/ascending and missing a bunch of options when comparing with the sort by menu for the libraries tab.
  2. Go to Home Page > Favorite tracks
    2.1. See it missing the sort by button that the elements in the libraries tab have
Timongcraft-fav-sorting
As all the duplicates, just create the smart playlist you want with the sort you want and use it instead of the default.
