When casting from my phone to a Denon AVR via UPnP, pressing the “Pause” button (also fast forward/rewind) on the physical Denon remote causes Symfonium to skip to the next track rather than pausing the current one.
Looking at the logs, the HEOS firmware does not send a PAUSED_PLAYBACK state. Instead, it instantly changes its CurrentTransportState to STOPPED.
Plex
Cast media to Denon AVR via UPnP.
Press “Pause” on the physical Denon remote control.
Track skips to the next item in the queue instead of pausing.
Enabled “Ignore remote stop command” in Symfonium settings
Toggled “Alternative UPnP flags” in the specific cast device settings (no change in behavior)
Are you referring to the Alternative UPnP flags renderer setting? I’ve run into the same issue whether it’s toggled on or off in the past, but I don’t think that was captured in the logs I uploaded. I’ll be able to upload a new one a bit later today.
I see, thanks. Just tested, enabling Stop casting on external changes in the AVR renderer settings does let me pause from the AVR remote now, but it also terminates the session. Guess there’s no way around that? It does seem to let me start a track with the remote without disconnecting (if cast is started from a paused state). Skip/rewind functions don’t seem to be doing anything. Uploading logs.
