Minor bug:
I have a Subsonic (clone) instance running behind a reverse proxy which is restricted to specific IP addresses, unless a specific header is set with a specific value (set in Symfonium under my provider as a custom header).
I can browse my music, but when I set under “Playback → Decoding and transcoding → Mobile maximum bitrate” to something other than “Original”, my playback stops working. I saw that I’m getting a bunch of 403s from my phone, and set an exception to allow
/subsonic/rest/stream.view
from all IP addresses, which resolved my issue.
I can only guess that the custom header is not sent at this point, otherwise my reverse proxy would accept the call.
Upload description: Implement5329
None
0. enable IP address-restricted subsonic behind reverse proxy, but allow a specific custom header to bypass IP address restriction
- send custom header to reverse proxy
- enable max bitrate for mobile
- attempt to stream
