Create custom buttons on home screen
Ability to create a custom button on the home screen and map it to a desirable action. Also let users choose the icon from available options or upload there own maybe?
For my use case I want to add my own “track mix” button on the home screen, map it to provider x and y but ignore z for example, or other variables that are available in the smart playlist list.
Unique buttons for every user. More creativity and flow.
For custom track mix, as far as I know, smart playlist is the only way but it involves more clicks for same outcome.
It’s one more click :wink: VS something insane to code and maintain for nearly no one to use.
Ok. Im not aware of the workload unfortunately to implement something like that.
You just gave it :wink: Smart playlists. Then either pin the playlist to home or favorite it and use the favorite playlist row.
I meant to code/implement the mappable button on home screen. :grinning_face:
Im already using the fav playlist also. Still would be nice to have a quick action button for certain things on my beautifully laid out home screen :wink:
