Connectivity to opensubsonic via Foobar client
My setup was
NAS Music Storage
├── Navidrome → Symfonium/mobile
└── foobar direct SMB access ->desktop
-> monkeymoto as remote
I was looking for below, but it doesn’t work as expected
NAS Music Storage
├── Navidrome
├── foobar using opensubsonic
→ unified remote Symfonium/mobile
Subsonic (Open)
Looking for options and possibilities.
Let me know if any log required
No idea what you want but Symfonium is not a remote control.
Can we cast from Symfonium to Foobar?
If have a working upnp renderer plugin.
There is a native UPnP renderer in development but it’s a little unstable at present: https://hydrogenaudio.org/index.php/topic,127849.msg1081539.html#msg1081539
If you wanted to try it I’d use foobar2000-x64_v2.26_preview_2026-04-30 and disable gapless playback in the renderer settings (in Symfonium).
Enabling gapless playback causes tracks to repeat, though I’ve just noticed the same when playing to TuneBrowser so it could be a Symfonium issue.
Thank you, very much. This really helps. Symfonium is able to see FB2k as one of upnp and able stream the music on server.
Next item, is there a way to play them as bit-perfect on FB2K. I also have small set of dsd & iso file and that to be handled. With this setup I see them treated as pcm.
I don’t know much about DSD, but if foobar intends to support it over UPnP then it’ll have to advertise the capability.
foobar currently advertises support for:
http-get:*:audio/flac:*,http-get:*:audio/L16:*,http-get:*:audio/x-wav:*,http-get:*:audio/ogg:*,http-get:*:audio/x-ogg-flac:*,http-get:*:audio/mpeg:*
I don’t know if there are official mime types for dff/dsf/dsd, but going by this post it looks like Symfonium expects:
http-get:*:audio/dsd:*, http-get:*:audio/x-dsd:*
