Connect issue on aliyundrive webdav
Hi symfonium devs,
I’m new and so happy to find symfonium, it works well and has nice UI.
After some configurations I found some complainment while connecting to aliyundrive(in China) webdav protocol, it lists the music items well but cannot play, could you have a look what’s going on here?
Many thanks!
Hua
Upload description: plutox
WebDAV
You did not upload logs so can’t really tell.
Hi Tolriq, thanks for your reply, I turn on the debug mode, and did some operations, then sent the log in app button, I cannot export the log,I’m not sure if you could see it. :slight_smile:
The server returns an error when accessing the file, does it work with mp3 or flac ?
I have uploaded some mp3 and flac files, which works fine, and some ape files still don’t work, I find aliyundrive don’t support ape files preview, that maybe be issue. :frowning:
Unfortunately I don’t really know, it’s probably some issue between ffmpeg and the server but since it’s a cloud provider there’s no way to get the details for the error.
thanks you for your help all the same, I convert ape files to flac, it works fine now.
Have a good day!
