Compact Player - Inverted Progress is all one color
When enabling the “Inverted colors” toggle for the Compact Player’s progress bar, both the played and unplayed portions are set to the same color. This makes it impossible to actually see the progress.
Upload description: Celorien_Compact_Inverted
Same happens with Theme colors and Adaptive colors.
Pic 1: not inverted. Played is bright blue, unplayed is dark blue.
Pic 2: inverted colors is enabled, same position in the track. Entire bar is bright blue.
I was hoping the feature would swap the two colors like it does in the expanded NPS.
Set Compact Player to use Bottom/Round progress bar styles and enable the “Inverted colors” option.
The entire bar will be one color regardless of track progress.
