Text and icon have sometime shown to not express a brighter color even though some icons can be brighter and more viable
Previous version had no issues with this cause it was consistent and it was just a settings to make it have color
All
Have background as Glow and background overlay at bottom 70
2.have most text and icons be using strong album color and some use album color primary or secondary
Provide the actual NPS style and the track to reproduce. You have full control over everything and as the changelog says, you might need to tweak your style.
From previous version
I’ll think I fix it thanks I found what was the problem should have kept them on Album accent color but some are still not as bright or vibrant as v15
I tried the Accent extraction modes on my settings some tracks looks amazing then others look unsee able it was never inconsistent for the previous version when you set them to “color” this over design layout made it impossible for my original design to thrive
Maybe add a another color like album primary color glow
As said I need the exact track and the exact difference you see and what you expect. I can’t guess and don’t have time to do random test trying to imagine your needs.
Seriously you are not helping here, it’s Sunday why do I need to ask ten times the same details ?
There’s a million settings and ways to extract colors, I need to know exactly what changed with what setting used before the update and result you expect from the settings you use, I can’t guess what you expect.
sorry, i sent this before its supposes to look like this
They become dimmer on icons and text some looks visible and pretty good but then others will have icon and text be less visible due to blending with the background colour
*Animated glow with background overlay down
suppose to get it like this for previous version v15
Your export currently selects Dominant extraction. V15 preferred a Vibrant color in dark mode and applied a stronger contrast boost, so the same artwork can now produce a different foreground color. Several elements in this style also use 65–70% opacity, which reduces their visibility further.
For a controlled comparison, set the affected icons to 100% opacity in both their normal and playing settings. That will separate the style’s dimming from the extraction and Glow contrast differences. It may not restore the exact v15 appearance.
