Colour Options Do Not Appear for Icons Without Active/inactive Modes
Beta
For text field icons, colour options do not appear for icons without active/inactive modes, only the overlay options. However if I switch to an icon with the active/inactive modes and change the colour there, it gets applied to all icons regardless of if they have said mode or not.
  1. Add an icon in a text field on controls and information.
  2. Choose an icon like “more actions” and you’ll see that you do not get any colour settings, only overlay settings.
  3. Choose an icon like “toggle cover and lyrics” and you’ll get the colour settings in addition to overlay settings.
  4. Notice that if you change the colour on an icon with active/inactive modes, it gets applied to icons without the mode regardless.
Screenshot 2 shows the options available for the “more actions” icon and screenshot 1 shows the options available for the “toggle cover and lyrics” icon.
Icon Color Selector
Isn’t the “color palette” option what you are looking for? (Just above Shapes)
That affects the overlay not the icon itself
It affect both, and if you set it to custom then both editors are visible. But I agree this is not very clear.
