Click on download manager notification does not jump to download manager
Not sure if this is intended, but when a download for the offline cache is running and I click on the corresponding notification, Symfonium opens the start page, while I would expect to jump to the download manager directly.
Sent via email:
20221123_103816
On all my devices it works, thanks Samsung will try to see if I can find something.
I am not sure if it worked before. The same thing works in Yatse though.
Not comparable :slight_smile:
May I suggest you hibernate for a couple of month ? :slight_smile:
I thought so.
Well, you could pay me to keep the bug findings under lock and key :money_mouth_face: Or you can relate me to someone else’s app which is as feature-rich as yours. But that will be hard, as I made you implement all the features I wanted from all the different apps I used before :wink:
Get a piano and play your own music.
