I would like for the “bottom compact tabs” under Portrait Navigation Styles to be centered around at least have the option for a centered version as the tabs leaning towards the left looks a bit distracting.
Would allow for me and others to the customisation option without any visual annoyances.
It allows for more personalization options.
Screenshot 1 shows what the “bottom compact tabs” looks like with four navigation tabs enabled.
Screenshot 2, for comparison, shows the same four tabs with the “bottom navigation bar” option.
