Can't stream to UPnP
I can’t stream to my UPnP speaker from the subsonic server (navidrome).
Streaming local file to the speaker works fine (tested with a local file and BubbleUPnP).
The strange thing is that I have Symfonium also installed in another phone running CalyxOS. The settings and the provider are the same. Yet streaming from this phone works!
Upload description: clancia
Open Symfonium
Open streaming menu
Select UPnP speaker
Wait for the playback ti migrate to the device
Try to reproduce any track
The settings are actually probably different :wink:
Be sure to not use complicated headers or enable proxy mode for the renderer to workaround UPnP limitations.
Indeed. Thanks for the reply.
I could not figure out what the problem was but I backed up the working device and restored on the nonworking one.
