Can't skip through tracks on android auto?
I can no longer skip through tracks on android auto, I only listen to long mix sets so this is quote a critical feature. The progress bar also doesn’t update with the progress though the tracks?
Google Drive
play a track on AA
dtokez
You need to provide logs reproducing the issue …
I went into the app and uploaded some, at least I thought I did?
Your log is empty. You need to enable logs, reproduce the issue from playback start to having the issue then send logs.
Hi there, sorry about that. I tried earlier and sent another log
Thanks will be fixed.
Great, thanks very much! It’s not very usable as it is.
Hey man. It’s still not working properly, I’ve just uploaded another log. Hopefully it helps, many thanks!
