Beta
The 2x2 widget never displays for me when a queue is open. The other widgets work fine.
- add 2x2 widget to Home screen
- play media
- check widgets
This isn’t a recent issue. I saw this a while back but at the time just used a different widget and forgot about it.
Not sure what to capture for logs. I started media playback and swiped up to exit to my Home screen. Then tapped one of the working widgets to pause and open the app.
Tested with Nova launcher, default LG launcher, and Lawnchair. All do the same.
Celorien_Widget
