USB Exclusive mode fails to obtain USB access on Pixel 10 Pro XL (Android 17), preventing native DSD256 playback.
I am experiencing an issue with Symfonium 15.1.0 on my Google Pixel 10 Pro XL running stock Android 17 (unrooted, locked bootloader).
When connecting my FiiO BTR17 USB DAC, Symfonium detects the device but displays the following message:
“USB access is missing for this device. Without it, playback falls back to Android default mode. Touch to request access.”
Tapping this message does not resolve the issue or produce a usable USB permission prompt.
With USB Exclusive enabled and Force PCM for DSD disabled, playing a DSD256 file results in the BTR17 displaying PCM 192K instead of DSD 11.2M.
Expected behaviour: Symfonium obtains USB device access and outputs native DSD256 through the BTR17.
Actual behaviour: Symfonium reports missing USB access and falls back to Android’s standard audio output.
The same Symfonium version successfully outputs native DSD256 using the same BTR17 on my Pixel 8 Pro running crDroid 12 (Android 16).
More importantly, USB Audio Player Pro (UAPP) successfully outputs native DSD256 on the affected Pixel 10 Pro XL running stock Android 17. The BTR17 confirms this by displaying “DSD 11.2M”.
This demonstrates that the affected phone and DAC support native DSD256 playback, but Symfonium is unable to establish the required USB access.
All
On a Google Pixel 10 Pro XL running stock Android 17, install Symfonium 15.1.0 (versionCode 127812).
Connect a FiiO BTR17 DAC via USB-C.
Open Symfonium and enable USB Exclusive playback.
Ensure “Force PCM for DSD” is disabled.
Accept the Android prompt to open Symfonium for the connected BTR17, if displayed.
Observe the message stating that USB access is missing.
Tap the message to request USB access.
Observe that USB access is still missing and no usable permission prompt appears.
Play a DSD256 track.
Observe that the BTR17 displays PCM 192K instead of DSD 11.2M.
For comparison, playing the same DSD256 track using USB Audio Player Pro on the same phone and DAC successfully produces native DSD256, confirmed by the BTR17 displaying DSD 11.2M.
Additional diagnostic logs:
I have uploaded Symfonium’s internal debug logs using the application’s “Share logs with support” feature, under the identifier Shadow-Blitz.
I have also independently captured Android system logs using wireless ADB while the FiiO BTR17 was connected via USB-C.
These additional captures include:
- Android logcat during Symfonium’s failed USB access attempt.
- Android logcat during successful native DSD256 playback through USB Audio Player Pro (UAPP).
- Android USB service dumps (dumpsys usb).
- Android AudioFlinger diagnostics (dumpsys media.audio_flinger).
Wireless ADB was used because the phone’s USB-C port was occupied by the BTR17 during testing.
These ADB logs are separate from Symfonium’s internal debug logs and are available upon request.
I would be happy to provide additional diagnostics or reproduce the issue using specific instructions from the developer.
My preference is to resolve this without rooting the device or modifying Android’s security configuration.
Shadow-Blitz
