Hello, I noticed that when I cast my songs to my Denon amp(upnp), the embedded lyrics are not available. But if I first play the song on the phone and then cast the song that is already playing, the lyrics become available during the cast. Kind regards.
Upload description: Jojoggy
pCloud
There’s no logs uploaded…
Seems you disabled the transcoding engine in the settings, and since the lyrics are in the file, the engine is necessary to extract them for now.
Do you think an update could fix the problem?
Tolriq
July 8, 2025, 12:44pm
6
Enable the transcoding engine ?
I had disabled it because it was transmitting sound in PCM instead of FLAC.
Tolriq
July 8, 2025, 12:49pm
8
No it does not do that sorry …
Tolriq
July 8, 2025, 12:54pm
10
Just in case you misread: The transcoding engine never and can’t transform FLAC to PCM.
There’s nearly never a valid reason to disable it.
I misunderstood, I’ll try
It’s fine, it works. I don’t remember why I disabled transcoding then
