Hey, probably something on my end, but can you have a look at the logs I just uploaded?
I can’t seem to get Auto play to work as it used to since Android 17.
I can manually start it, but its not auto starting reliably with Android Auto and BT devices.
Upload description: telrod11
More than likely something I have set wrong, but I don’t remember making any changes.
I also, uninstalled, reinstalled, and restored my backup before sending this up, and I still am seeing the same issue.
Just have an existing queue, and then pause it for a period of time. I can get BT / AA to work, if I delete that queue, and start a new one, but it is struggling to start the existing queue.
This release is suitable for development, testing, and general use. However, Android 17 is still in active development, so the Android system and apps running on it might not always work as expected .
You play with fire not me , the … might be misinterpreted on my side as blaming me for your actions
They broke it in Android 15 without warning, they reverted some changes after to fix, and now they officially block this. Considering I’ve tried to get some attention on the needs many times, I have no doubt that they absolutely don’t care and won’t support this use case.
The linked document shows that Google removed that ability on purpose and will probably not bring it back unless you have more power than me to contact high level Googlers on AOSP to change their mind and add those uses cases as allowed.
Read what I write and the links and the history and use Google search after all you are still an engineer no ?
In Android 15 they did what they are doing now in Android 17 but did not announce it as such and so updated the code to match the description of their docs so we could workaround after their patch.
They have now officially disabled the feature as they wanted in Android 17 and properly documented the change …
