BIT Perfect feature
With the Bit Perfect feature, the audio output can be purer from the source and file so that there is no upsampling or resampling
In order to bypass Android Audio Output, if the Bit Perfect feature is applied, the sound output can be pure without Android resampling/upsampling effects
The sound output is purer without the effects of Android
Other application solutions
There is no other solution, except for the perfect bit
Please don’t lie on the form :slight_smile:
This was already implemented :grin:
Where can I find the feature, is it in the playback settings?
Can you show me how to activate it?
