When the “link pitch to speed” toggle is enabled, make both the pitch and speed sliders visible and interactive. moving either one should move the other proportionally.
When the toggle is on, only one slider is usable as the driver. If you think in terms of pitch rather than speed (e.g. “I want to go up a semitone”), there’s no direct way to do that, you have to just move the speed around until you find the right pitch
Allows pitch to be adjusted in exact semitone values, currently when set via speed, you end up with imprecise values like -3.98 semitones. Also useful for anyone who wants to listen at a different pitch without the audio artifacts that come from changing pitch independently of speed.
