Better offline support
Ok so was able to reproduce a race once, that’s strange that it happens 100% of the time on your side.
Can you confirm that if you manually click on the last song of the queue in the queue list it does load again correctly?
It does not. I click Queues, I click “Smartplaylist 12”, the last song appears in the “currently played” song (on the bottom of screen), but it’s over now, I click it to see the queue, and this last song is there, it’s last. I click it, the icon on the album quickly turns from > to II, and the queue immediatelly disappears, without any music appearing.
I’ve shared the log.
Don’t restore queues after all your tests.
Go to playlists and play it, let’s not mix again tons of different things.
Then click on the last song of the queue (so this triggers a change of song).
If your queue is already at the last song and you press it, it pause it, so it can’t trigger the refresh in your case.
Right… So if I click myself on the last song, it does extend the queue. In my previous tests I was clicking the timeline of the current song near the end, to let it change to the next song naturally, upon end of previous song, and in that case the queue is not extended.
Of course, such extended queue has most songs repeated, because the “last played” smart play list didn’t remove them because I didn’t actually play the songs, but just skipped to the end, but that’s probably expected for this test.
It depends on your settings how you skip the songs and positions.
But so it’s the race, just no idea why it happens every time for you.
So both will be fixed in next release.
Cool, thanks, I’ll test it then
To report back: now this feature works as expected, cheers
Update: the filter should be “last played > 30 OR play count = 0”.
Without play count it just plays the same songs it played before. I was trying to understand for a while why it doesn’t pick up new artists I added to my collection while repeating the same songs it played.
